I have a problem whit the extrude feature
Hello i want to make a extrude, in this cabriolet leg from the 3d sketch projected sketch. But geometric conditions error apears. Can someone please tell me how can i do it properly. I attached the part so you can have a look.
Nearly same solution like above.
Answered with a tutorial: https://grabcad.com/tutorials/i-have-a-problem-whit-the-extrude-feature--1
hi, thank you for you reply. Acctualy i was refering at the extrude cut. Is there a way to make the extrude cut 5 mm inside the piece like in the photo
Here is how you do it.
