In Autodesk Inventor 2012, ribbon bar is small. How to change it back to large icon with text.
I don't know of any other way unfortunately. But I have attached a print screen to this answer just so you can double check that you're hitting the correct button. If you hit the big one it should cycle through, the little drop down one will only give you options to minimize the ribbon.
