In Wind Tunnel SolidWorks Simulation, inlet wind speed (V1) is 5.6 mph, how to carry out the SolidWorks Simulation and arrive at the same outlet wind speed (V2) of 48.3 mph as calculated in my result.
My Wind Tunnel inlet wind speed (V1) is 5.6 mph and l calculated the outlet wind speed (V2) to be 48.3 mph. I need someone to help me on Wind Tunnel Simulation in SolidWorks how to simulate this results in SolidWorks and get the same results. Please kindly assist me in Wind Tunnel SolidWorks Simulation of these results. Thank you all for your quick responses
With any duct or pipe that has a quantity of air going in one end, the same quantity of air coming out must be the same. For the air to be coming out at a faster velocity than the air going in the area of the outlet must be smaller than the area of the inlet end. We can not change the amount of air, if the temperature or pressure remain the same. You have little change of simulating your wind tunnel without a basic knowledge of fluid dynamics.
