pls tell me how to get snapshot pro-e 05???
View > Model setup
from there choose your scene, lights, orientation .... etc.
when you are happy with your model and you want to render it go to view > Render Window. to save it go to file > save a copy > JPEG or PNG or whatever format you want.
to change the rendering quality and the output image resolution go to View > Model setup > render setup
Play with it, it is not complicated, you should be able to fine your way through.
