Tutorial - Modeling Crank Shaft in SolidWorks?
This is tutorial on making crank shaft. The main problem with making such design is with reading the dimensions on the drawing sheet. Well i have solved it for you. In this tutorial we will go through simple extrusion operation to make crank shaft.
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-modeling-crank-shaft-in-solidworks
