what is difference between 2D and 3D grain in rocket motor ?
Is there any difference in shape or something else?
2d grain is one where the cross sectional shape and area is the same from one end of the propellant to the other. The most common would have a star shaped internal profile that is extruded along the z-axis of the propellent. The profile is constant along the z-axis.
3d grain is such that the cross sectional shape and surface area changes from one end to the other. The profile changes along the z-axis.
The combustion and thrust performance of 2d shapes are easily modeled using manual methods. 3d shapes require much more complex computer analysis of the combustion and thrust profiles.
