What is the difference between Global goals and Surface goals in Solidworks flow simulation? Jong 28 May, 2012 11:09 AM What is the difference between Global goals and Surface goals in Solidworks flow simulation? To analyze drag force on a surface, which goal should be used? 1 Answer Sudhir Gill Answered on 29 May, 2012 08:01 AM In case you want to study results on a particular surface than use surface goals. In case the results for whole Assembly use Global goals.
