AutoCAD 3d Modeling | Learn How to Use Extrude, Loft, Revolve, and Sweep Commands in AutoCAD | CADable | CADable tutorials
Welcome to CADable, where Engr. Ibrahim Omer will guide you through this Autocad 3D modeling tutorial. In this video, you'll learn how to use the extrude, loft, revolve, and sweep commands to create complex 3D models in Autocad.
We'll start with a brief overview of 3D modeling in Autocad, explaining how each command works and providing practical examples of how they can be used. Then, we'll dive into the details, showing you step-by-step how to create 3D objects using extrude, complex shapes using loft, rotational objects using revolve, and swept objects using sweep. We'll also cover the differences between solid and surface extrusion.
This tutorial is perfect for beginners looking to gain valuable skills and knowledge in Autocad 3D modeling. We encourage you to practice along with us and use the play-pause technique to improve your skills. If you have any questions or comments, feel free to leave them in the comment section, and we'll do our best to answer them.
Remember, practice makes perfect, so keep practicing and applying what you learn to your own Autocad projects. Thanks for watching, and we hope you find this tutorial helpful!
#autocad3dmodelingcommands #autocad3dmodeling #solidextrusionvssurfaceextrusioninautocad #CADable #CADabletutorials
Follow our Channel:
https://www.youtube.com/c/CADable
