Crankshaft, Flywheel Mounting Flange, Shaft, Main Bearings, and Keyway (i4 Engine)
Tutorial to construct the crankshaft, Flywheel Mounting Flange, Shaft, Main Bearings, and Keyway of a i4 Engine that will be Connected with the 4 Cylinder Pistons by using the connecting Rod Visualization and Modelling Muhammad Annawfal Rizky Sihotang 2106718281
  1. Step 1: Step 1: Start Constructing Using XY Plane
  2. Step 2: Make Construction Rectangle
    By making this rectangle construction, will be a lot more easier to find the center for the next sketch steps
  3. Step 3: Sketching counterweights
    Sketch a circle from the center point with 44 mm distance and 72 mm for the diameter
    • Draw line on each side of the circle
    • Connect the line using the arc tools
    • Set the dimension at 33 mm for the line
    • Set the tangent at 80 for the arc line
    • To make the line parallel for both side and the circle, the Constraint tangent can be used
    • To make the edges symmetric, the Symmetric constraint can be used
  4. Step 4: Extruding Counterweights
    Extrude the sketch with 15 mm thick to make the counterweights
  5. Step 5: Sketching CrankPin
    Sketch Circle with 72 mm diameter on the front side of the Counterweights
    For the backside, Sketch a circle with a 54 mm diameter
  6. Step 6: Extruding Crankpin
    Extrude The Front Crankpin with 38 mm thick and the Back Crankpin with 46 mm
  7. Step 7: Mirroring Counterweights
    Using the Midplane between the Crankpin and the counterweight, make a new work plane
    After making a new work plane Use the Mirror tool to duplicate the Counterweights
  8. Step 8: Reverse Counterweight
    SKETCH
    Sketch the counterweights but in opposite ways from the parts before
    • Sketch a circle with 72 mm diameter
    • Draw a arc line with the same degree like the counterweights before
    • Connect the arc line with the circle with a line that symmetric from the left and right side
    EXTRUDING
    • Extrude the surface with 15 mm thick
    CRANKPIN
    • Draw a circle with 54 mm diameter and extrude it with 46 mm thickness
    • Using the midplane, mirror the reverse counterweight
    • Draw the next circle on the bottom part of the counterweight with 72 mm diameter and extrude with 38 mm thick
    1. Ste
  9. Step 9: Final Mirroring
    Make a midplane for the final mirroring
    Select all the parts before and use the mirror tool to duplicate and finish the crankshaft body
  10. Step 10: Flywheel Mounting Flange
    SKETCHING
    • Draw a circle with 144 mm diameter at the left side of the crankshaft
    • Draw a construction circle with 110 mm diameter
    • Create a small circle with 10 mm diameter
    • By using the circular pattern tool, create 8 circle around the construction circle that have been created
    EXTRUDING
    • Extrude the big circle with 15 mm thickness
  11. Step 11: Shaft, Keyway, Main Bearings
    Shaft and Main Bearings
    • Start 2d sketch on the left side of the Crankshaft
    • Draw a circle with 72 mm diameter
    • Extrude with 38 mm Thick
    Keyway
    • Create a circle with 32 mm diameter in the Shaft Surface
    • Extrude with 80 mm thick
  12. Step 12: Fillet
    Fillet all the edges, as shown in the picture below with 3 mm for the radius edges
