Design of an radial engine with animation
Every radial engine has an odd number of cylinders, and they fire in alternating order. ... As the cylinders fire, the rod assembly rotates around the crankshaft, spinning it like a bell crank would. A counterbalance weight sits opposite from the rod hub to prevent engine vibration
Step 1: Follow the video
