Design of impeller for centrifugal Pump
Here is a tutorial of "How to create impeller for centrifugal pump using solidworks. For video tutorial kindly check the link https://www.youtube.com/watch?v=TUxKqjk4vA0
  1. Step 1: Understanding 2D drawing
    First of all we will try to understand the 2D drawing for impeller for centrifugal pump.
    In above drawing, 2 views are given out of which left side view looks simpler as compared to front view.
  2. Step 2: Sketching the left view on plane
    Select right plane and sketch on it
    Then draw half sketch on same plane as we will be using revolve command
  3. Step 3: Revolving the sketch
    Go to features, select revolve
    After revolve, the model will look like this
  4. Step 4: Creation of hole for shaft
    Select front face and sketch on it.
    Create a sketch using circle and lines.
    Go to extrude cut
    Select through all
    Finally it will look like this
  5. Step 5: Creating blade
    Select front face again and sketch on it
    Draw the sketch as shown in figure
    Now go to extrude, select depth as 14mm
    and click ok
  6. Step 6: Create 6 blades
    to create other blades, we will use circular pattern
    Select face as reference, and feature as extrude. Enter no. of count as 6 and then click ok.
    It will look like this
  7. Step 7: Final rendering
  8. Step 8: Video Tutorial
