Fluid Flow Analysis- ANSYS
In this tutorial , the part contains different pipe cross sections in which fluid i.e water is flowing at different velocities and temperature.
We will see the changes in the velocity , temperature and pressure at the output.
I have used the Fluid flow (Fluent) module in this tutorial
