Helical Spring Design With Catia
You can see the coil spring design I made with catia from the pictures below
First we open the part design to design the object.
We make a point assignment in the opening page.
And we are plotting a plane. -
Then go to the workbench screen,
We are entering the shape generative shape section. -
Here we select the command helicopter, first to the point then select the plane
We are publishing at the appropriate size. -
Then we go back to part design.
Using the rib command on the part design menu, we are starting to create a spiral broadcast.
Selected areas.
And we have completed the helix broadcast.
Render process.
