how can i create a cable joint in catia v5???
Follow the following steps to make a Cable joint.
Click the Cable Joint icon in the Kinematics Joints toolbar or
select Insert -> New Joint ->Cable from the Menu bar.
The Joint Creation: Cable dialog box appears.
Now you need to select two prismatic joints -
Select Prismatic Joint 1 and Prismatic Joint 2 in the specification tree
If the prismatic joints are not created yet, use the create button. The Joint Creation: Prismatic dialog box automatically -
Click Ok to end the cable joint creation.
The mechanism can be simulated
The cable joint is created and identified in the specification tree.
Now expand the cable joint you just created, the embedded leaf joints are displayed. -
Click the Simulation with Commands icon or double-click Mechanism.1 in the specification tree to display the corresponding
simulation dialog box.
