How do I add a specific cut pattern with a draft around a curved surface?
In order to Focus on your question I will Keep the bottle thread out of the tutorial.
    First step is to create the bottle with a 0.5 mm debossed wall than the expected Dimension.
    Revolve Feature gives you the following solid
    Next step is to create a wrap Profil. Improtant is to Keep some gap between the mountain edge and the bottle edge (untill which edge the Profile is still cylindrical)
    I kept 0.1 mm gap in this case
  5. Step 5:
    Use wrap function in order to wrap the Profile around the bottle
  6. Step 6:
    Next step is chamfering.
  7. Step 7:
    Last but not least filleting
