How do I make a curvature continuous fillet in SW?
Here is the tutorial and the file I used.
    Start SolidWorks.
    On Front plane in part mode make a sketch like this using spline.
    Extrude it by height say 50mm.
    Again enter front plane >> sketch and again a spline like this. And have a coincident relation with the end point of previous spline.
  5. Step 5:
    Extrude it by 50mm also.
  6. Step 6:
    Under surfaces tab choose fillet.
  7. Step 7:
    Select face fillet type.
  8. Step 8:
    For face set 1 select extrude-surface 1 and for face set 2 select extrude-surface 2. adjust direction to inside region.
  9. Step 9:
    Choose front view for better view of the fillet to be formed.
  10. Step 10:
    Click fillet options in fillet property manager.
  11. Step 11:
    Check curvature continuous. And you can see the change in fillet.
  12. Step 12:
    Change the fillet radius to 20mm.
  13. Step 13:
    Click OK and the fillet is formed.
  14. Step 14:
    Under Evaluate tab choose zebra stripes for tangency analysis. And zoom to the surface along the surface-extrude1 and the fillet. You can notice the continuity of zebra stripes.
  15. Step 15:
    Same goes for surface-extrude2.
  16. Step 16:
    Disable zebra stripes and you are done.
