How to add(Make on one body ) surface area with solid part ?? ( Help to make mold in solid works )
Custom Mold Insert Design
    Have a look at this stage, you will have 3 solids. 2 mold cavities and the original part.
    I used Surface extrude 2 (red Surface) 2 to cut the insert pin into two
    Then i used Surface extrude 3(yellow surface) to cut the pin out of the cavity
    In this step I have Splitted both mold cavity using Surface extrude 3
  5. Step 5:
    As you see after Splitting 1 I have 6 parts
  6. Step 6:
    After Splitting 2 I have even more; 7 parts
  7. Step 7:
    Now Comes the combining step.
    Have a look at the photo one side of the insert pin is already combined. On the other side using Combine 2 i am joiing turkis and pink part together
  8. Step 8:
    In the end you should be left with 5 parts.
    2 mold cavity, 2 insert pin and your designed part
