How to create a torsional spring in Creo Parametric 2.0
"How to create a torsional spring in Creo Parametric 2.0"
Create a spring using helical sweep command -
Select the plane passing through the start point of the spring and select sketch -
Create a sketch starting through the center point of the sweep section to add the angled legs -
Apply sweep command on the sketch -
Now create a datum plane at the center of the spring -
Mirror the sketch about this plane -
Now mirror the mirrored sketch about the center plane -
And apply sweep command on the sketch -
We have a torsional spring
