How to create endmill?
HOW TO CREATE ENDMILL
create circle 50mm dia on the front plane.
extruded boss/base 250mm.
create sketch on this face. -
something like this
exit sketch.
create new sketch on the same face. -
create circle 50mm,
create helix:
pitch 300mm
rev. 0,5
start angle 0
clockwise
...exit sketch. -
cut-sweep using sketch and helix
create sketch on this face:
Right click on edge - select loop - convert entities.
exit. -
new sketch on same face:
create circle 50mm -
and then create TAPER helix.
Step 11:
cut-sweep
Step 12:
create Axis
Step 13:
circular pattern
Step 14:
...just sharpen it... :)
