How to create Radial Engine Assembly\Design of Rod Bush, Piston and Link Pin, Plug
Radial engine, Type of internal-combustion engine used mainly in small airplanes, in which the cylinders (ranging from five to as many as 28, depending on engine size) are mounted in a circle around the crankshaft, sometimes in banks of two or more.
  1. Step 1: Follow the video
