How to create spur gear in Siemens NX?
This tutorial presents the modeling of an external spur gear in Siemens NX.
The detailed modeling process is demonstrated on this video:
https://youtu.be/pVPjDyOn6R4
UPDATE: At ~ 2:40 leave the Limit options at default (At Point). See the errata video for the reason:
https://youtu.be/PUpdlyQcaOs
    Copy these parameters into a text file and save it. Rename the file extension to .exp.
    [degrees]alpha=20 //Reference Pressure Angle
    c=sqrt(1/(cos(alpha))^2-1)/pi() //Parameter of Involute Curve
    [mm]m=3.5 //Module
    [degrees]phi=arctan(yc/zc)+90/z //Rotation angle
    [mm]r=m*z/2 //Reference Radius
    [mm]ra=r+m //Tip Radius
    [mm]rb=r*cos(alpha) //Base Radius
    [mm]rc=m*.38 //Tooth Blend Radius
    [mm]rf=if(m>1.25)(r-1.25*m)else(r-1.4*m) //Root Radius
    t=0 //NX Parameter
    [mm]xt=0 //x Coordinates of Involute
    yc=rb*(sin(deg(c*pi()))-cos(deg(c*pi()))*c*pi())
    yt=rb*(sin(deg(t*pi()))-cos(deg(t*pi()))*t*pi()) //y Coordinates of Involute
    (Integer) z=25 //Number of Teeth
    zc=rb*(cos(deg(c*pi()))+sin(deg(c*pi()))*c*pi())
    zt=rb*(cos(deg(t*pi()))+sin(deg(t*pi()))*t*pi()) //z Coordinates of Involute
    Launch NX, create a new model file, push the CTRL+E keys and imports the expressions.
    Create the involute curve by Law Curve command.
    Create a circular pattern on the involute curve.
  5. Step 5:
    Draw a line which starts from the end point of involute and tangents the curve. Set its limit by equation.
  6. Step 6:
    Launch the Join Curve command and join the line and the involute curve.
  7. Step 7:
    Draw the tip and root circles by full circle. Draw a tangent circle for the tooth blend.
  8. Step 8:
    Trim the unnecessary parts of the curves.
  9. Step 9:
    Mirror the involute curve and the tangent circle.
  10. Step 10:
    Trim the tip and root circles.
  11. Step 11:
    Create a circular pattern, set the parameters.
  12. Step 12:
    Extrude the curves to get the spur gear body.
