How to make an animation for a compression spring in Solidworks 2011?
Tutorial to make animation for a compression spring in solidworks.
1. Model a spring and make the centre line always visible as shown in the figure.
2. Make the bottom part of the spring surface flat with the process shown below. Use “surface cut” tool for this purpose.
3. Repeat the same process for the top portion.
4. Make a part similar to the figure shown below or of a simple shock absorber.
5. Make the bottom part of the spring coincident to the part created in the above step as shown.
6. Right click on the sketch shown in blue colour and edit it. Before editing the part you must save your assembly file.
7. Make the line and the part co-incident as shown in the figure.
8. Click on “motion study” at the bottom of the solidworks window.
9. Place the model as shown in the figure and drag the bar in the timeline represented by orange color to a certain time as per your requirement.
10. Drag the part out as shown in the figure. The bars in the timeline will automatically get generated.
Step 11:
11. Now drag the orange colored bar to a greater length on the timeline.
Step 12:
12. Click on “calculate” button as shown.
Step 13:
13. Save the animation.
