How to model a Centrifugal Pump Body (Spiral construction) using Inventor 2014?
We have to abide by all the conditions from the technical drawing
Note: You can watch my live tutorial for modeling this part here: https://youtu.be/yxEAv2p31zw
    1. New work plane at 45° from XZ Plane around the Y Axis (see 1, 2, 3, 4 steps)
    2. New sketch: Circle Ø26.75 with center at 123.5 on the same vertical with the origin (Center Point)
    3. Coil tool with Spiral option (Pitch=28, Revolution=7/8)
    4. Result from Coil/Spiral applying
  5. Step 5:
    5. Creating of 5 sketches (5 circles), where the last 4 of them are related to the Center point only
  6. Step 6:
    6. Loft tool on 5 sketches, using the spiral curve on the spiral feature as Centerline
  7. Step 7:
    7. Result from Loft tool applying
  8. Step 8:
    8. Revolving half circle on S1 around its diameter on 180° to create a hemisphere
  9. Step 9:
    9. Extrude tool on a circle (radius=123.5) in the Center point using a 24 simmetrical distance
  10. Step 10:
    10. Move Bodies tool to move the (unique) solid 200 to the back
  11. Step 11:
    11. New 5 similar sketches (only one dimension differs), related to the same Center point as above
  12. Step 12:
    12. Changing color of the Solid1 using Right click/Properties
  13. Step 13:
    13. Loft tool with New solid option, on the 5 sketches with Centerline from the spiral curve
  14. Step 14:
    14. The result is another solid in the same .ipt file (or two solids of different colors)
  15. Step 15:
    15. New sketch on an existing plane - a circle is automatically projected (like in 005 or 008 picture)
  16. Step 16:
    16. New work plane parallel with XZ Plane through the circle center (see 1, 2, 3 steps)
  17. Step 17:
    17. New sketch on XZ Plane - a centerline from the projected circle center, and other 3 lines
  18. Step 18:
    18. Revolving the closed loop to obtain a conic feature associated with the Solid1
  19. Step 19:
    19. New sketch for the Solid2 with a line projected from the circle of the Solid1
  20. Step 20:
    20. The sketch also related to the Center point will be revolved - attached to the Solid2
  21. Step 21:
    21. A sketch created on the sloped plane is revolved between it and the next one, to fill the gap
  22. Step 22:
    22. Filling the central hole of the Solid2
  23. Step 23:
    23. New sketch with a circle of Ø310 in a new work plane at -65 from the XZ Plane
  24. Step 24:
    24. Extruding the circle To next with a taper of 3°, as in the above part drawing
  25. Step 25:
    25. A new sketch in the plane XZ to extrude simmetrically on 120
  26. Step 26:
    26. The result of the last two extrudes
  27. Step 27:
    27. Move Bodies tool on Y Offset = 200 to get back the Solid1
  28. Step 28:
    28. Combine tool to subtract (Cut) the Solid1 (as Base) from Solid2 (as Toolbody)
  29. Step 29:
    29. The result (intentionally sectioned)
  30. Step 30:
    30. A new sketch for creating the revolved external body
  31. Step 31:
    31. Result of Revolution
  32. Step 32:
    32. A new sketch for creating the revolved internal body
  33. Step 33:
    33. The result (intentionally sectioned)
  34. Step 34:
    34. New sketch with a Ø34 circle to create a boss for a G1/2" hole
  35. Step 35:
    35. The ISO Pipe G1/2" hole, through but not through all
  36. Step 36:
    36. Rib tool to create a rib, starting from a sketch in XZ Plane with a sloped line at 30°
  37. Step 37:
    37. Final part
