How to model Letter Balance in Solidwoks - Assembly
Letter Balance - Fully Defined
Before start the assembly, copy Little bolt four times with diferent names
Create a new assembly and insert the Stand on this position
Insert a Right scale
Use Mechanical mates Hinge with this references and values -
Insert a Left scale
Insert a Large scale
Use Standard mates Concentric with this references -
Use Standard mates Coincident with this references
Insert a Little bolt 1
Parallel mate this twoo planes
Coincident mate this twoo planes
Step 11:
Insert a Little bolt 2
Step 12:
Step 13:
Step 14:
Insert Little scale
Step 15:
Other holle the same
Step 16:
Step 17:
Insert a Little bolt 3
Step 18:
Step 19:
Step 20:
Insert a Little bolt 4
Step 21:
Step 22:
Step 23:
Insert a Left hinge
Step 24:
Step 25:
Step 26:
Insert a Right hinge
Step 27:
Step 28:
Step 29:
Step 30:
Insert a Bolt
Step 31:
Step 32:
Step 33:
Insert a Right crank
Step 34:
Insert a Left crank
Step 35:
Insert a Top
Use Standard mates Coincident and mate this twoo planes -
Step 36:
Step 37:
Use Standard mates Tangent and mate this twoo faces
Step 38:
Step 39:
Use Standard mates Coincident and mate this twoo faces
Step 40:
Step 41:
Insert a Upper hinge
Use Advanced mates Width and mate it with this references -
Step 42:
Use Standard mates Distance and mate this twoo faces
Step 43:
Step 44:
Edit the Stand part and create a new plane with this references
Step 45:
Use Standard mates Limit Distance and mate it with this references
Step 46:
The Assembly must be Fully Defined
