How to Reset Catia V5 to default
This tutorial presents the steps required to reset Catia V5 to default. The process requires the software to be reset in order to apply the changes.
Step 1: Reseting all the parameters to default
Here are the steps on how to reset CATIA V5 settings to default:
- Open CATIA V5.
- On the menu bar, click Tools > Options.
- In the Options dialog box, click the Parameter Value to Default tab.
- In the All Tabs list, select all the tabs.
- Click Yes.
- Click OK to close the Options dialog box.
- Restart CATIA V5.
This will reset all the settings in CATIA V5 to their default values. This includes the toolbars, menus, workbenches, and preferences.
Here are the steps on how to change P2 to P3 in CATIA V5:
- Open CATIA V5.
- In the Options dialog box, click the General tab.
- In the User Interface Style list, select P3.
- Restart CATIA V5.
This will change the interface of CATIA V5 to the P3 style.
Here are some additional things to keep in mind:
- You can only change the interface to P3 if you have a P3 license for CATIA V5.
- If you change the interface back to P2, you will lose any customizations that you made to the P3 interface.
