Part 17 : Piston Ring
A piston ring is a metallic split ring that is attached to the outer diameter of a piston in an internal combustion engine or steam engine. The main functions of piston rings in engines are: Sealing the combustion chamber so that there is minimal loss of gases to the crank case. Blueprint parts retrieved from http://www.inventorwizard.nl/blueprints/index.html summarized in folder https://drive.google.com/drive/folders/1G_wAXvDLRlHb-FcoeNGU3P11jWXxuHjO?usp=sharing.
Step 1: 17. Piston Ring - 6 Cylinder Radial Engine Inventor Tutorial
