ProE Tutorial: How to create parameter for Pattern feature / sampling
Step for reproduce: How to create parameter for Pattern feature / sampling
Create model with holes (sampling-tool in 2 directions (ex. 5 right and 3 up=15))
Set custom name for dimensions
a. Select dimension
b. RMB > Properties -
c. Select Tab Dimension Text and set custom name > Confirm OK
Apply your custom names for all dimensions for Pattern feature
Select Tools>Relations…
Create new relation: Sum_of_holes=Number_of_holes_01*Number_of_holes_02 (where Sum_of_holes is new parameter into drawing) and confirm OK
Create drawing and drawing view with dimension (You can use Show and erase functuionality)
For diameter dimension of hole change the text to: (see the pictures)
Where:
&SUM_OF_HOLES – convert parameter to drawing note
[.0] – set zero decimal placement for parameter
@D – system create real number for dimension -
Confirm OK
Note: if you change the number of hole for Pattern feature - system will change the information in the drawing automatically – parameter SUM_OF_HOLES is driven by relation
