S-shaped battery cooling geometry in ANSYS
Creating an S-shaped cooling geometry in ANSYS or any other simulation software requires a good understanding of fluid dynamics, heat transfer, and simulation tools. It may also involve several iterations to achieve the desired battery system cooling performance.
Step 1: Start with Battery Geometry
Begin with a 3D model of the battery you want to cool. This model should include the battery cells and their housing.
Step 2: Create Cooling Channels
Design the S-shaped cooling channels within the battery housing. These channels should be strategically placed to provide uniform cooling across the battery cells. You can use ANSYS Design Modeler or any other CAD software to create these channels.
