Scissor Lift Animation in SIEMENS NX
This mechanism is used in devices such as lift tables and scissor lifts. Modern low-profile computer keyboards make an extensive use of it as well, installing each key on a scissor support to ensure their smooth vertical movement, allowing the use of a cheap and reliable rubber dome contact set, instead of expensive and complex array of mechanical switches.
Step 1: Follow the video
