Soccer Ball Design - Fusion 360 Tutorial
In this Fusion 360 tutorial, I'll teach you how to make a soccer ball out of a 3D sketch. We'll use Fusion 360's surface tool to create the ball's surface and then we'll use the thicken tool to make it a solid. We'll also project edges to surface, apply constraints in 3D and work with the move, rotate command. We will use several techniques to define planes.
This Fusion 360 soccer ball tutorial is perfect if you want to learn how to create a soccer ball. With this tutorial, you'll be able to create a realistic soccer ball that you can use in your projects. So get started today and learn how to make a Fusion 360 soccer ball!
Step 1: Soccer Ball Design - Fusion 360 Tutorial
