Solidworks Tutorial #137 How to Design Air Intake Filter in Solidworksby Solidworks Easy Design
The air filter prevents dirt and other foreign particles in the air from entering the system. The air filter is usually located in the air stream to your throttle valve assembly and intake manifold. It is found in a compartment in an air duct to the throttle valve assembly under the hood of your
Step 1: Solidworks Tutorial #137 How to Design Air Intake Filter in Solidworksby Solidworks Easy Design
