SpaceClaim basic tutorial - variable spring
SpaceClame basic tutorial - how to make variable spring
    1.open new design
    2.draw circle
    3.draw line
    4. select pull
    5. select revolve
    6. select line
    7. select circle ( select surface, not circle line)
    8. select revolve helix
    9. taper angle: 30
    pitch: 7 (if circle diameter is less, in this example, circle is 6 mm)
    height: 14
    10. enter or click in the empty
    11. taper angle:30
    pitch: 20
    height: 50
    12. enter or click in the empty
  5. Step 5:
    13.taper angle: -30
    pitch: 20
    height: 50
  6. Step 6:
    14. taper angle: -30
    pitch: 7
    height: 14
  7. Step 7:
  8. Step 8:
