The Ultimate Tutorial: Designing a Single Stage Helical Gear Box (1:2 Ratio) #361 #designwithajay
A single-stage helical gearbox is a type of gearbox that is used to transmit power and torque from a motor to a driven shaft. The gearbox consists of a single stage of helical gears, which are cut at an angle to the shaft axis, and mesh together to transfer power.
Step 1: The Ultimate Tutorial: Designing a Single Stage Helical Gear Box (1:2 Ratio) #361 #designwithajay
