Tutorial - Applying boundary condition in flow simulation?
Here is the tutorial.
In this tutorial we will use the file prepared in previous tutorial.
Click on flow simulation analysis tree in property manager.
Now right click the boundary conditions and select insert boundary condition.
Right click on the inlet face and select other. Now select the inner face for the inlet.
Select the inlet volume flow and enter the discharge value .8m^3/sec.
Click OK.
Again right click the boundary condition and select insert boundary condition.
Repeat the same step but this time select pressure opening in boundary condition type and select static pressure. Keep the default values and click OK.
Select the inner face of the third lid and select the pressure opening type with static pressure and click OK.
Step 11:
Now all the boundary condition are defined.
