Tutorial - Creating isometric circle (Front view) in AutoCAD?
Here is the tutorial.
Start AutoCAD.
Use line tool and input these values=
(0,0),
@10<270,
c. -
Now draw lines to the mid-points of the the lines.
Draw these lines.
Use circle tool and then select this intersection as center.
Select the end point of the line.
Again circle tool and select the intersection.
To the end point of the line.
Select circle tool and select the corner.
To the mid-point of the upper line.
Step 11:
Again circle tool and end-point.
Step 12:
To the other end-point.
Step 13:
Trim tool and select all.
Step 14:
Trim away the components leaving the circles to arcs.
Step 15:
Delete all construction and we have circle.
