Tutorial How to Make a Dazzling Golden Pearl Teapot in 3D StudioMax
here :) follow please
    Make a teapot in perspective view port with radius 70
    Increase Teapot segments to 10.
    Apply Lattice modifies from modifier list in Modify Panel and select “joint only vertices”.
  5. Step 5:
    In Joint group set Geodesic Base type to Icosa and set radius =2 and segments =2, don’t forget to check the smooth check box.
  6. Step 6:
    Now it’s time to set up your rendering engine. Press F10 to bring up Render Setup Dialogue box or click “Rendering” from Menu and click Render Setup.
  7. Step 7:
    From Assign Renderer Section, click on Choose renderer button in front of production and select V-Ray as your renderer. Be sure that you have already installed the V-ray renderer for the respective version of you 3ds max application 9, 2008, 2009, 2010 or 2011.
  8. Step 8:
    Now place VrayPlane in viewport anywhere in the scene from Geometry section.
  9. Step 9:
    Click on lights and select Vray and select Vray light and draw two light over the teapot like this with intensity multiplier =30.
  10. Step 10:
    Now let’s have some fun with materials. Hit M to bring up Material Editor, select a slot and click standard button. From material/map browser select VrayMtl and click OK.
  11. Step 11:
    Set Diffuse, Reflect and exit color like this and apply it to the Teapot by dragging material slot onto teapot.
  12. Step 12:
    Select second material slot and do the same as above, but now we are going to prepare material for the floor. So here click on diffuse (small square button) and select any bright wood map from map browser and click ok. I have selected oak1.tga.
  13. Step 13:
  14. Step 14:
    Click on go to parent button to go to main interface.
  15. Step 15:
    Set reflect color to light grey (see the image).
  16. Step 16:
    Apply this material on v-ray plane by dragging it.
  17. Step 17:
    Now it’s the time to set up the environment. Just press 8 on your keyboard to bring up environment dialogue box. Click on the “none” button and from standard, double click on bitmap and select any indoor HDRI Image or you may download it from the internet; they are not scarce.
  18. Step 18:
    Drag this button to a new slot in your material editor.
  19. Step 19:
    Set mapping to spherical environment.
  20. Step 20:
    Press F10 for render setup and Turn on Indirect Illumination check box from indirect Illumination tab.
  21. Step 21:
    Set Irradiance Map current preset to Very low. If you want to render it in less time, you may increase this to get more realistic result.
  22. Step 22:
    That’s it, we are finished. Set a dramatic angle of your view in perspective view and hit F9 to render and watch what have you achieved for yourself in 3D Studio Max.
    Final Result :
