Tutorial how to make synchronous belt
tutorial: how to make chain
file chain
firstly open a sketch to front plane and draw sketch like this
use trim command
use circular pattern command
connect the circles and use circular pattern command again
and extrude the sketch
open a sketch side of part and draw 2 circles
extrude it
go back side, open a sketch. close the back side with extrude
use fillet command
you can add a thing like this
Step 11:
all done:)) your synchronous belt is ready. very simple
