Tutorial: How to use drafting workbench in Catia V5?
Tutorial to use drafting workbench in Catia V5.
Open the model for which drafting is to be performed.
Switch to drafting workbench
A new drawing wizard opens up. Choose the appropriate option. Here i chose a blank page.
Window->tile vertically
You will get a view as shown.
Click on front view from the menu
Or get it from
Insert->views->projection->front view -
Click on the face as shown.
Place it on the blank page.
Click anywhere on the page.
Step 11:
Click on front view again. Choose a different plane.
Step 12:
Similarly drag and drop it on the blank page as in the previous case. Similarly get other views also by selecting different planes.
Step 13:
Right click on the drawing-> properties
Step 14:
Select the options as per requirement-> click OK
Step 15:
Edit->sheet background
Step 16:
Insert-> Drawing-> Frame and title block
Step 17:
Choose the title block->apply->ok
Step 18:
Insert->geometry modification->transformation->scale
Step 19:
Uncheck duplicate mode- Select value->ok
Step 20:
Edit->working views
Step 21:
Save as->*.catdrawing
