Tutorial - Jog feature (Sheet-metal) in SolidWorks?
Here is the Tutorial.
    Start SolidWorks in part mode.
    Top plane>>Sketch.
    Draw a rectangle.
    Under Sheet metal tab click Base flange/Tab.
  5. Step 5:
    Keep the default settings and click OK.
  6. Step 6:
    Under Sheet metal tab click Jog.
  7. Step 7:
    Select the top face of the base flange.
  8. Step 8:
    Create a line at 60º angle.
  9. Step 9:
    Exit the sketch. Now the Jog property manager will show.
  10. Step 10:
    Select the fixed area. The black dot represent the fixed area.
  11. Step 11:
    Change the Jog offset distance to 30mm and click OK.
  12. Step 12:
    Now we have the Jog feature obtained.
