Tutorial - Modeling CSK head sq. nut coach bolt in SolidWorks?
Here is the tutorial.
Start SolidWorks in Part mode. Top plane>>Sketch.
Draw a circle of 24mm dia.
Extrude it by 2mm.
Top face>>Sketch.
Select the edge and then convert entities.
Extrude it by 6mm and 60º draft.
Reference Geometry>>Plane.
Select the circular edge. Click OK.
Plane1>>Sketch.
Draw a Polygon.
Step 11:
Extrude it by 10mm.
Step 12:
Top face>>Sketch.
Step 13:
Draw a circle tangent to the sides of the polygon.
Step 14:
Extrude cut with draft at 60º.
Step 15:
Top face>>Sketch.
Step 16:
Step 17:
Extrude it by 50mm.
Step 18:
And we have the part.
Step 19:
After making the threads.
