Tutorial - Modeling Unified screw threads on bolt in SolidWorks?
Here is the tutorial.
Start SolidWorks in part mode.
Top plane>>Sketch.
Draw a circle of 20mm dia.
Extrude it by 50mm.
Top face>>Sketch.
Draw a polygon inside a circle of 32.5mm dia.
Extrude it by 10mm.
Top face>>sketch.
Draw a circle tangent to sides of polygon.
Extruded cut.
Step 11:
Check flip side to cut. Draft enable at 45.00º.
Step 12:
Chamfer.
Step 13:
At distance of 3mm & angle 45º.
Step 14:
Top plane>>sketch.
Step 15:
Select the outer edge and then convert entities.
Step 16:
Curves>>Helix and spiral.
Step 17:
Defined by Pitch and revolution. Pitch=3mm and revolution = 15.
Step 18:
Right plane>>sketch.
Step 19:
Draw a profile like this. Since pitch is 3mm so keep the length be little less than pitch since at 3mm it will have intersection error.
Step 20:
Sweep cut.
Step 21:
Select the profile and the helix as the path.
Step 22:
And we have the unified screw threads.
