Tutorial - Solving 2D Truss problem using Mechanical APDL (ANSYS) Part 2?
In this tutorial we will go through the third step. We will review our results.
Goto General Postproc >> Plot Results >> Deformed Shape.
Select Def + undeformed. Click OK.
We have deformation plot. Now goto Plot Results >> Contour plot >> Nodal Solu.
Select DOF Solution >> Displacement vector sum and click OK.
Now we have displacement plot.
Again goto Nodal Solu and select von mises stress under stress. Click OK.
We have von-Mises plot.
Click PlotCtrls and then select Capture image.
Now the result image will be in seperate image.
Again PlotCtrls Menu and select Numbering.
Step 11:
Check KP, Line and Element numbers & click OK.
Step 12:
Now we have the numbering for element.
Step 13:
Again goto PlotCtrls >> Animate >> Deformed shape.
Step 14:
Select Def + undeformed and click OK.
Step 15:
The animation will start. Click Close.
Step 16:
Goto PlotCtrls Menu and then Animate >> Save Animation in case you want to save the animation.
Step 17:
Goto General Postproc >> Plot results >> Vector plot >> Predefined.
Step 18:
Keep it to DOF solution and click OK.
Step 19:
We have the vector plot.
Step 20:
Finally we have solved the problem in APDL.
