Tutorial - Using fit spline tool to merge splines into one in SolidWorks?
Here is the Tutorial.
    Start SolidWorks in Part Mode.
    Front Plane>>sketch. Make a spline.
    Draw another spline tangent to this one.
    Under sketch tab click the spline tool arrow and select fit spline.
  5. Step 5:
    Select the spline one by one. Check the delete geometry and uncheck the closed geometry. Keep the tolerance to a minimum.
  6. Step 6:
    Click OK and we can notice that two splines are merged into one.
  7. Step 7:
    Extrude the surface. We can notice that there is only one face.
  8. Step 8:
    If we hadn't merged the splines than we have two faces.
