(VIDEO TUTORIAL) Solidworks Tutorial #162 How to Make Gear Pump with Roller Bearing in Solidworks Easy Design
Gear pumps use the actions of rotating cogs or gears to transfer fluids. The rotating element develops a liquid seal with the pump casing and creates suction at the pump inlet. Fluid, drawn into the pump, is enclosed within the cavities of its rotating gears and transferred to the discharge.
Step 1: Solidworks Tutorial #162 How to Make Gear Pump with Roller Bearing in Solidworks Easy Design
Step 2: Rendering Images...............
