Weldments Material
I see, but i try to open the cut list as you mentioned, and the sub-window is the same (as picture). i already follow your guide in the system option and select Show for solid bodies. I try to create a new part and the folder came out as a "Cut List" and not as "Solid Bodies". Did i messed up somewhere?
