Is it possible to plan torispherical tops on inventor?
Accepted answer
Hi Rodrigo.
You cannot do this in the Sheet metal environment because the material is being deformed. Sheet metal allows for Bends, which it calculates using a K-Factor, your Dome is not going to flatten, as the material is being distorted on 2 planes.
You could use the Unwrap command in Inventor (2020 version onwards), to flatten the dome once you have created the geometry.
https://clintbrown.co.uk/2019/03/27/inventor-2020-new-unwrap-command/
2 Other answers
Hoi Rodrigo,
try the links below.
I wil attache a ipt model.
https://www.slawinski.co.uk/products/torispherical-heads/
https://www.slawinski.co.uk/cms/upload/downloads/Slawinski-Datasheet-EN.pdf
Greetings,
Danny
