I need help designing the model at three steps
Oh, I see. Then you have full of works on it. Ok, no problem.
Do you need just the 3d files or do you want to design with your own dimensions?
I only need the 3D files.
Small note: Please do not use ToolBox for the Rockerarm screw
Ok, and what dimension do you need for these parts?
I don't understand.
I meant for example: How much is your bolt diameter?
How much is your rocker-arm length and...
and other dimensions.
OK. I will answer you before the 22 october.
ohhh then it is a huge project, not a simple one. It needs calculations and so other things to find suitable dimensions.
My team did such kinds of industrial projects before and it take time.
Is it a specific kind of ic engine? or it is a standard and common one? May I ask its name? maybe we have it on the team database.
This is a 6.0L Chevrolet LQ4 V8
Hi Hajiba. How are you?
Ok, I will inform you.
And please check your inbox, thanks.
