Help me with my project autocad 2d
Hello, can you guys help me with my project? I need to project a single speed reducer gear with a power of 11kW, 1000 hours lifetime, 760 rot/min, distance betwen shafts axes 112 mm, and the number of teeth for z1=20, z2=90 with a radial-axial ball bearing.
It should look exaclty like in the dwg file but with different dimensions and a different ball bearing. I really need your help, thank you!
Read what I have written here:-
https://grabcad.com/questions/error-while-opening-assembly-files
you need to provide all the files that make up this assembly The IAM file is not enough.
Here is a file that might help your needs:- Gearbox Casing
