how can import solid body from catia ro solidwork 2015
I import the file from catia to solidworks but I have problem
the imported file known as shell surface (otherwise its a solid form)
how can make it to solid form ?
and where my problem is ?
u can try it open in IGES format. save the file in IGES format in catia then again open it solidworks
There is a missing face from one of the fillets. See the attached picture.
To fix it, you can use the Fill command.
As it is a corner fillet, I'd set all faces to be tangent, then also set the option to create a solid.
I'm trying to fix it now to upload a parasolid model, but it is taking forever to calculate the patch.
