how to assemble the engine, tyres and suspensions on a baja roll cage in PRO E wildfire 5.0
plz reply
firs you check the unit and you have to open the assembly mode of Pro/E 5.0 and than Import all the component and then apply just simple constraint like Align and Mate to them
You have to open the assembly mode of Pro/E 5.0 and than Import all the component and then apply just simple constraint like Align and Mate to them.... This will make your assembly.
Also you gave to give any detail of what you have made so that it is easy to tell..
